Old Sep 10, 2010 | 04:10 AM
cruzinquick's Avatar
cruzinquick
Default Re: Went to the track again. Disappointed.
Originally Posted by Holycrap
Ok im going to go ahead and ask this. Whats the best way to heat up street tires? Go to the water pit, brake torque at 1,500-1,700 and just release and go full throttle??? I have never done this and DONT WANT TO BREAK ANYTHING. Yes i know, im a rookie.
Mikes reply is sound advice. Anytime you drive through the water to do a burnout, remember that you are drying up the rears during the burnout. The problem is with the deep tread the fronts have, they still have water in them. So driving around the water is important. Now you have a choice to reverse into the water and the pull up to do your burnout or do a dry burnout.
The key thing to avoid is a dry hopping. This when your rear tires grab then lose grip then grab again very quickly. It causes a jerking or hopping action. This is when damage is done to the rear end. So be careful.
