Old Sep 11, 2010 | 08:14 AM
kingkub57's Avatar
kingkub57
Default Re: Problems With Starting the SRT, Battery Related?
I would check your cables to make sure it did not corrode to much and break any of the wires inside the cables causing a poor connection and not allowing enough current flow, you could also through a charger on it over night, cause it could be low on charge, make sure your alternator is charging, I would also check the battery again just because its new does not mean its good, I have seen new batteries be bad right off the shelf.
