Old Sep 12, 2010 | 04:31 AM
Thirteendog's Avatar
Thirteendog
Default Re: Best Way to Reach Wheel Well Access Panel?
Personally I removed the whole wheel well to remove mine. You might have better luck, I'd also like to remind you that you should un screw the two torx screws that hold the bumper to the wing. This will give you some wiggle room to remove the headlight assembly.
