Old Sep 12, 2010 | 05:03 AM
No_Dominion's Avatar
No_Dominion
Default Re: Best Way to Reach Wheel Well Access Panel?
Personally I removed the whole wheel well to remove mine. You might have better luck, I'd also like to remind you that you should un screw the two torx screws that hold the bumper to the wing. This will give you some wiggle room to remove the headlight assembly.
Hmm, good to know... Where exactly are those located on the bumper?
This will be the first time I've had the Crossfire on a lift or done anything more than basic work on it, so I'm sure I'll be in for a treat...
