Originally Posted by Axel
I just found the alarm module that Lennex3 mentioned on the previous post, I disconnected and I believe that module is defective, I will replaced it shortly, but for now the car is working ok, I can lock the door, and it is not screamming all the time.
Axel, did just disconnecting the alarm module give you a check engine light or cause you any other problems. How does it disconnect? If I can just disconnect it. I may call that fixed. Then put in a aftermarket alarm. If I could find a reasonable way to remove every bit of the stock wiring, switches, computers and relays from this car I would.
