Old Sep 15, 2010 | 09:22 AM
gryfan's Avatar
gryfan
Default Re: Fill-up with Nitrogen!!
ken,
gryfan here from canada. the other advantage of nitrogen is that it does not leak through the side walls as easily as air.the sensors will not tell you your tires are low ...as often. also i believe that nitrogen does not have as high a moisture content as air ....and thus is easier on the pressure sensors. this is what i have been told....can't verify either idea.
cheers from the colonies!
gryfan
