Old Sep 17, 2010 | 07:11 PM
oledoc2u
Default Re: Problems With Starting the SRT, Battery Related?
Originally Posted by Kolme
!!! Got the SRT6 back yesterday with the battery problem still persiting, replaced the entire ground terminal connector andddd ta-da! fixed.. It must have been ridiculously corroded... Thanks guys!
Kolme
these little cars are very voltage sensitive....so, keep things clean...the resistance caused by corrosion, or loose connections will cause you problems...dang puters....
