Old Sep 18, 2010 | 10:58 AM
onehundred80
Default Re: Please help me remove alternator/generator I'm such a novice
Originally Posted by mp3wizard
Guys im trying to remove my alternator, I've had a good look around the forum, Im following this guide on page 27-28
http://homepage.mac.com/gregmeach/XF...-EngineSys.pdf
Basically so far I have loosened bolt 2 on the picture and It's not completely off, just sticking out, not sure if i need to remove it completely?
Basically i'm struggling to figure out how to remove the accessory belt? Is it just brute force? as I've yanked it really hard a few times and it doesn't seem to be able to move at all....
I assume once I get the belt off I will then be able to wiggle the generator about and disconnect/remove it?
Please help, I know nothing about cars, Just trying to save on garage bills....
I have a new alternator coming as this one has failed according to the garage...
I also need to replace a fuse as it's currently not cranking, its just clicking... but I guess I'll come to that later
To remove the belt you have to lock the belt tensioner and your pdf says see page 7-45.
You must not remove the alternator with the belt under spring pressure. That's dangerous.
