sorry to tell you.... but your on the WRONG side of the engine.... the alternator is on the passenger side..
PLEASE tighten any bolts you have loosened back to spec...
Go here and download the 2004 Crossfire Service Manual..
https://www.crossfireforum.org/forum...ollection.html
then go to Section 7, Cooling, page 7-42... this will show you the drawing of how the belt wraps and which pulley is which.... note #7 (tensioner) and #5 (alternator/generator)..... read down a couple of pages and it will show you how to take the fan belt off..... then use your pdf file to remove the correct bolts on the alternator and disconnect the wiring....
