Re: Please help me remove alternator/generator I'm such a novice
most likley its a torx bit needed to loosen the tensioner. it works as a fulcrum and wont loosen the nut itself. when counter clockwise tension is applied the whole pulley moves and provides enough slack to slip the belt off. then slowly let the pulley move clockwise until it rests or you will find your arm stuck at the bottom of the engine bay!!
