Old Sep 19, 2010 | 10:37 AM
James1549
Default Re: Please help me remove alternator/generator I'm such a novice
PS I don't see any need to remove any fan. You do have a NA?
Here are some quick pix of a spare tensioner I had on the shelf.
This is what you need to pivot or release the tension on the belt:
You only need to remove the pulley if the bearing would be bad, or you need access to one of the bolts to remove the entire assembly:
