OK here's for EVERYONE.. The main problems with electronics in ANY car is 99% grounding issues. Whenever you start to upgrade ANYTHING on your car you should tackle the BIG three FIRST. #1 Battery to frame #2 Motor to Frame #3 Frame to Body. In addition to the big 3.. Battery to Motor and Battery to Body ALWAYS helps. 4ga MINIMUM wire should be used. This will provide all the extra grounding anyone will normally ever need..whatever stock grounds there are LEAVE THEM THERE!!! Unless they are in the way of you adding more.
Your battery will last longer, and your car will generally crank easier, your lights will be a little brighter, stock stereo a little louder, depending on your car you can gain hp and torque.. More grounds=More power supply=Better spark=Happy motor=Happy owner
some companies sell dinky 8ga kits for $100 don't settle for less than 4ga!
