Swap the wheels with the coupe to rule out the tires.
Well that was half the problem. When I swapped the wheels I removed (6mm spacers from the rear). The spacers were non hub centric and allowed the rear tires to be mounted slightly off center. Now that they are removed the unbalanced ride in the rear is gone. The rumble/roar noise is still thier regardless of which wheels/tires are on the car. Thanks
