Re: Replacing the IC Pump with CM30P7-1 Johnson Pump
Great write up. When I did mine I took the old pump off while still attached to the bracket. I almost lost my freakin' mind trying to locate that hidden nut on the back side that faces down. Now I've got to go back in there and check my pump's wiring...Your write up will help refresh my memory. Thanks
