Originally Posted by huudoo
i have a SRT-6 the car front bumper is too low for me to use ramps
some members have made their own, just look and see if the ramp's
will scrape the front bumper...
when you change the O rings lay them out in order like in the link..
and make sure to look at the oil filter housing, mine has a green dot to
line it up ..
so not to over tighten / under tighten the filter housing
The filter housing needs to be tightened to 22ft-lbs right? In that case, wouldn't it just be hand tight?
Also, I'm pretty sure these will work. I checked them out before I left the store parking lot, and they look like they will work ok.
