Thread: Got Rust?
Old Oct 2, 2010 | 09:12 AM
IBLUBYU's Avatar
IBLUBYU
Default Re: Got Rust?
Originally Posted by TomStratRT
I finally got around to taking pictures of the Crossfire since we just bought a new 14 megapixel digital camera. I've been telling you guys/gals about how my wheels make a rhythmic metal on metal sound and squeak/squeal when braking (and now when going in reverse). Well, here's why:
I haven't removed the wheel myself, but I have been told by the local Chrysler dealer (who has a specialist that works on Crossfires, thank god) that the rust will work itself off just by driving the car over time. The problem is, this car is garage kept five days a week. Doesn't leave much time to work the rust off.
Is there anything I can do to remove the surface rust with a spray or something? It's really irritating me at this point.
Thanks.
It's interesting that you took pics of the rear wheels. Is this where you hear the squeaking? If it is .... then you may have "rust" inside the emergency brake drums.
Try running your car with the ebrake just slightly on, and see if the squeaking diminishes after a couple of short runs. If it does, you will need to pull the rear wheels and cleanup the emergency brake drums inside. OR .... just pull the wheels and check inside the drums and the shoes ...... Hope this helps.....
