Old Oct 2, 2010 | 09:18 PM
LantanaTX's Avatar
LantanaTX
Default Re: Key wouldn't turn !
this is a common problem that gets worse. check the sticky key thread. there are two ways to fix it. You can replace the ignition or modify the existing one so that it can never happen again. I chose the latter. The down side of fixing it so that it can't happen again is that you will lose the steering lock. when you turn the key it pulls the pin out that locks the steering. If it can't pull the steeting lock pin the key will not turn. Elimitating the steering lock pin will fix the problem forever. I decided not to change the worn parts becuase I didn't want to deal with it in the future when they wore out again and they don't seem to last very long.
