Old Oct 3, 2010 | 07:18 PM
  #91 (permalink)
bmorgan's Avatar
bmorgan
Default Re: Where Do We Go From Here?
Originally Posted by 32krazy!
do you have the full oem exhaust? removal if the res. and sec. cats along with the oem battery should be well over 100 lbs. use the shuriken battery, and some clk rims with dr,s and that should be worth at least 2/10's faster times putting you near the 11's!! if its feasible woodys trick of using bolts thru the floor for the seats allows quick removal of the pass seat on raceday. and big piece of dead weight gone.
Steve, the bolts through the floor is not for faster removal. It would actually be faster to remove them from the top. I removed mine in about 2 minutes. The purpose for putting the bolts through the floor is for easy removal in the event that the electric seats quit working.
