Old Oct 3, 2010 | 08:13 PM
SNAKEWOLF's Avatar
SNAKEWOLF
Default Re: Help Ignition issue
The SKREEM contains an RF transceiver and a microprocessor. The SKREEM transmits RF signals to and receives
RF signals from the ignition key transponder through a tuned Sentry Key Antenna Ring that is wired to the
SKREEM. If the Sentry Key Antenna Ring is not mounted properly around the ignition lock cylinder housing, communication
problems between the SKREEM and the ignition key may arise. These communication problems will
result in ignition key transponder-related faults. The SKREEM also communicates over the Controller Area Network
(CAN) data bus with the Powertrain Control Module (PCM), the Instrument Cluster, the Body Control Module (BCM),
and/or the DRB III
T scan tool.
TRY AND MAKE SURE THE RING IS INSTALLED CORRECTLY ENSURE THAT THE PLUG FOR THE RING IS PLUGED IN ALL THE WAY I PULLED MINE OUT WHEN I DID THIS JOB.
IT IS NOT A FUN JOB IF YOU HAVE TO REPLUG IT IN.
GOOD LUCK
OTIS
