Old Oct 4, 2010 | 05:29 PM
  #97 (permalink)
tri_zombie's Avatar
tri_zombie
Default Re: Where Do We Go From Here?
Originally Posted by Thumper SRT6
Did I read this right? You ran low 11's without using nitrous? With just the mods listed in your sig? No port & polish work? Was this recently?
Sorry for all the questions, but it seems like you have the setup a lot of us are looking for.
Hey Thumper
Yea pretty much what's in my sig. I never figured out away to retard the timing enough to use the N2O until now (I'll be testing that this month). I'm going to run 35# and if all goes well bump it up to 75# and see what my knock sensor count is.
The only things different is I added an "on command" auxiliary fuel pump running parallel to existing pump and filter with PSI regulator I Also did some work to the intake (modified and extrude honed) this winter.
Best time: 1/4 Mile = 11.38
Followed with a 11.45 and 11.50 thirty min. apart I really need some rubber under the car. I'm spinning the hell out of tires on a well prepped track.
I do have a secret though, Running at 12' above sea level
