Understand - I figured all the drag racing SRT6's with their rev limiters adjusted to 6,200 RPM were shifting into fourth just prior to the finish.
I would guess that there is a time penalty during that shift - so if you could hold third just a tad longer (and perhaps 1st and 2nd) you could drop another .10 to .20.
Do that with minus DA weather on well prepped track, with sticky drag radials, minus your front grill, all non-essential items removed and you just might lay down an 11.XX run.
is this in the tcu program brian? all srt-6 and slk32 have the same gear.. 3.07 yet im just hitting the redline almost shifting into 5th when i hit the traps. ill have to look but think my rev limiter is set to 6100 rpm, not sure. im well into 4th long before the end
