Thread: Interior Lamp
Old Oct 7, 2010 | 01:45 PM
UK ken's Avatar
UK ken
Default Re: Interior Lamp
Ken,
you'll have to slowly and carefully pry the clear lens away from the housing. Pry at all 4 corners in sequence straight out. Do not tilt or tip as it is a bit brittle.
Once removed, I suggest instead of tweezing the bulbs out, remove the housing from the roof by taking out the 2 Phillips-head screws. The bulbs sit in little removable holders of their own.
If you push on them from below, they are easily damaged.
Cheers.
Thanks for info..will remove (hopefully) this coming weekend..will post ourcome..
Cheers
UKKen.
