Old Oct 9, 2010 | 08:45 PM
No_Dominion's Avatar
No_Dominion
Default Re: Headlight problems
Originally Posted by Cissy
Thanks for the reply....however, I have much more than "cloudy". It's as if the lens is deeply corroded, very rough to the touch. Simply horrific.
I notice they talk about wet sanding, but some say don't do that. Very confusing.
Thanks anyway. Much appreciated. I wish I did have only cloudiness and/or foggy/hazed lens.
Well at this point, as bad as your lenses look, I doubt that trying a sanding technique would do more harm than good, so it's probably worth a shot. There are a few kits you can pick up in auto part stores that come with the different grits you'll need. The rougher ones should be able to take off the outer corroded layer you're talking about so that the finer ones can do the trick of making them clear again.
