Originally Posted by oledoc2u
if you have the divider pulled up in the back and hooked into the loops on each side, that is all you should have to do...the back should be straight up toward the back...not it the down position...if that doesn't do it then there is a problem somewhere else
....make sure there isn't anything lying down in the mechanism somewhere...now the switch that lets the windows down, is tied to the latch mechanism...so the top switch may be fused, this I would have to research...so, I would check all the fuses at this point...I am on the road, so I can't do that research from here...
Yup the divider is straight up and it is hooked into the loops however only the right loop has a metal thing that looks like a sensor....are they BOTH supposed to have that metal thing? and the right also has a plastic piece that looks broken. So I wonder if the problem is that there is a missing sensor on the right loop or if it's not detecting the latch due to the broken piece. It fits snug into the loops and its exactly where it looks like it should be. Thanks again for all the help.
