Old Oct 11, 2010 | 09:50 AM
Black03AR's Avatar
Black03AR
Default Re: CAB Module / ABS Pump
Thanks rcompart, you obviously have had good experience in removing these parts, I'm a little stuck on how to remove the whole unit.
I can see that there are 3 lugs that protrude out into the wheel well that hold the pump in place - but how are these secured? There are no nuts or bolts!
Also, will I have to bleed the brakes once I re-install the pump with the new CAB?
Thanks for your help
Regards
AR
