Old Oct 12, 2010 | 02:16 AM
  #191 (permalink)
billvp's Avatar
billvp
Default Re: its ugly but getting there... twin-charged SRT-6!!!
Originally Posted by dinasrt
I got the following from a post by tri_zombie. This is a srt6 he is talking about of course, and don't know if this helps you or not. It's more than what I would know how to do for sure. "2) Fuel injectors cleaned, balanced and calibrated and matched up (interestingly enough my flow rates were 17% off between all the injectors) flowing 20% more plus a better pattern. cost about 150.00 each send out at least 12 so they can get the best match then sell the others off on ebay or add them to the intake ports (just after the supercharger) as a secondary set and control them with a mini piggy back for additional fuel (MD SRT6).
3) additional (second) fuel pump running 5-bar pressure @ WOT Waldig gave me the idea."
Originally Posted by Eric
sounds like the cost on all that would be alot... found Hi-Flow Fuel Injectors that TVT are selling.. might be more cost efficient
TVT Design, Crossfire/Mercedes/Genesis Performance Parts - SRT6/C32/SLK32
I'm not sure where the $150 came from, but it most definitely is NOT $150 apiece to flow balance injectors. He might have meant a total of $150 to clean and test all 12 if you wanted to do that (which defintely seems like a good idea).
