attached picture.
You have to remove the bottom panel and loosen a bolt then adjust the position of the assembly and re-tighten the bolt.
Follow the pdf instructions to step 8 then you should be able to see the bolt.
pdf can be found at
https://www.crossfireforum.org/forum...tml#post504963
