Originally Posted by Eric
ill get some iat mesurements next time i run her.
I have a johnson cm30 liquid intercooler pump, 1gallon intercoller tank (bothe pump an tank moved to the trunk), and a LET heat excanger witch is biger then the stock one.
Im sure there is a way to set it up to stop useing the sc but I dont know how yet
Thanks Eric
IAT will be very interesting.
You can put a switch that cut out the S/C, just to test if it works.
If it works, you get 100 hp more, at same intake manifold pressure, and you can name the switch Warp Speed. :-)
