Old Oct 15, 2010 | 06:15 PM
jaylogs's Avatar
jaylogs
Default Re: Hazing Headlight Lens
Originally Posted by Joliet John
Yeah... Hookit style paper. Probably a weird size disk in the kit. Easy to find 3" or 6" discs at an automotive store. I didn't realize you were sanding with the drill. I did mine by hand. 500 grit on a drill, you're seriously getting into that plastic. Do you run into an issue with melting it? That would definitely clog up your paper faster.
Yeah, it's smaller than 3". It would be easy to start to burn if you leave it on one spot too long, so you just got to keep moving it around. But given how badly it was hazed, it really did the job! And yes, it does clog it up more, I extended the life a little bit by brushing it off as much as I could. It still took about and hour to hour and a half to get it good.
