Old Oct 17, 2010 | 01:43 PM
CrossfireLTD's Avatar
CrossfireLTD
Cool Re: Low Battery Problem
Originally Posted by turkeyman
I went to start my 05 Roadster and the battery was too low. I placed my charger on for 10 min and started it. As I was driving down the road I could hear a strang roar from under the hood. The electric radiator fan was running at full tilt. I turned off the car and restarted, instantly the fan started. When I got home I took off the Neg battery connection and left it for 5 min. Reconnected the terminal and started the car. All back to normal. I will be replacing the battery ASAP. Hope this helps if others run into electical problems.
Once the OEM battery has drained its best to just replace it......you did the right thing.
