Originally Posted by MAYAman
This looks great. Here is my suggestion for the skirt as the front looks perfect. Taper the skirt slightly as you reach the front fender opening so the front is not at wide as the rear. Also, at the rear, on the top edge of the skirt, make the flat top part taper into the rear wheel arch ever so slightly so the cut off is not so harsh. Its all about making it look as factory as possible. You've succeeded with the front, just a little work to the side will make them much better. Good work.
I was thinking something similar to your suggestions..
I was thinking about raising the back line up near the top corner of the rocker panel so it slants down to the front. Also having it taper down in the front to just a small lip like you stated.
