Old Oct 19, 2010 | 12:23 PM
PNA's Avatar
PNA
Default Re: Headlight Adjustment
Originally Posted by amx1397
but ! there are little white plastic nut looking adjustments screw and one you insert a torque screwdriver in to make the adj, get your hand in there , with your lights shinning on a building (car level) ( at night) and adjust away. there are only two adjusting screws ,,, jim
That's the best / most straight forward description I've seen. If you want more details, there are some extensive threads on adjustments on the forum as well. Do a search and the'll pop-up. I was looking for guidance on same issue yesterday and found them with explicit details about distance, height etc. Also, a few things to beware of as well -- such as the bulb being inserted properly and the adjustment screws working in reverse. Anyway, good luck. I haven't attempted to adjust mine yet. My left light seems to need a slight adjustment upward - and I hope it's as simple as slowly turning the correct screw in the correct direction to bring it upwards.
Good luck.
