Old Oct 19, 2010 | 04:46 PM
onehundred80
Default Re: Headlight Adjustment
Originally Posted by hazmatman
Thank you all so much! I am a new owner of a 2005 Crossfire and just picked up the vehicle. The headlight lens on the drivers side was hazed and needed polishing. Maybe during the polishing, the assembly was moved slightly up?? But, there is no signs of a previous accident. I just noticed the incorrect angle while driving this morning.
Abel
I doubt that polishing the lens would move them. If you have just purchased the vehicle then it is quite possible that the bulb is incorrectly positioned or the headlamp unit has bee played with at some time.
Before adjusting the unit make sure the bulb is in its seat properly. You do not have to release the spring clip to put it in the correct position. Grasp the socket and try to move it around, do not pull just keep the spring pressure on it, if its out of place it will click into position.
Only when you are sure it is OK adjust the unit with the screws.
