Old Oct 20, 2010 | 09:12 AM
BoilerUpXFire
Default Re: possible stock grille swap for upper and lower billet unit
Originally Posted by oledoc2u
old man, does the florida grille dig into the front bumper cover?
+1, when I first saw them in design, I was not a fan, then I saw the optional gloss black finish and I was hooked, looks like they did an amazing job, thanks for getting them to undertake this.
Edit: In order to install the Florida ones, you need to drill your bumper cover, as they do not use OEM mounting points, there is no way I am drilling my bumper cover, thats for sure.
From their email to me: "Grille Technologies Chrysler Crossfire billet grille upper grille is a full replacement of the factory grille. The grille has 3 welded brackets on the left, right and bottom of the billet grille. You will align the billet grille in place on your Crossfire marking where these brackets touch. Next you'll drill out the bolt holes required to mount. Last step is just mounting the grille up with provided bolts, nuts, washers."
