MAYAman is correct, when you use double sided tape and there is a constant separating force you will find that it will eventually come apart.
These components would appear to be quite heavy due to the material used and should be hollowed out to save weight. How much do they weigh?
Each side should be less than 2lbs. Urethane is pretty light.
