Old Oct 21, 2010 | 05:48 AM
FUBU's Avatar
FUBU
Default Re: Need Help with Electrical Gremlins
Originally Posted by cruz427
Thanks guys,
I did try playing around with all the connections in the junction box to see if I could duplicate the issue but there doesn't seem to be anything going on in the junction box contributing to the problem. The battery may be the first attempt at solving the issue. Although it has shown no signs of failure. it always cranks over hard and strong. Even after the car died on the expressway it cranked hard and strong when I re-started it. I know I've had motorcycles that would do some really wierd stuff when the battery went but, they usually showed some signs of a weak or dead battery.I'm busy for the next few days so i probably won't get to address the battery until early next week but I will give you an update after that fix. Thanks
Have you done the re-soldering thingie? That solved my car from shutting down on the high-way.
