Originally Posted by ROBBSOUTHTEXAS
I have a 2005 Roadster that is doing the same thing. I already replaced the Crankshaft position sensor. Now is stall occasionally. This occurs sometimes when I am driving. It just dies. I have power because the lights and radio stay on but the engine does absolutely nothing when I turn the key. After about 5 minutes it starts up. A real pain in heavy traffic!! If you get any good answers, please send them to me as well. I would appreciate it!
Robb
Did you Look at the Relat Control Module (RCM)? It has 5 relays in it that have the solder joints come loose. One of those relays is the fuel pump which would cause engine stopping and a no restart. Sometimes heat was causing these issues when the solder joints came loose. Also check for burnt relays which can also be cleaned.
https://www.crossfireforum.org/forum...tml#post430634
Try this from Tighed1 something to look at anyway. It is an easy fix if this works. Tighed1 is a good guy he will do the soldering if asked if you are not handy with a soldering iron. Just follow the directions on the link here.
