Old Oct 24, 2010 | 07:11 PM
oledoc2u
Default Re: 2005 SSB SRT-6 Roadster - TX - ASP Pulley - $19K
Originally Posted by ShawnQ
Hello all,
A friend of mine is selling his SSB SRT-6 Roadster.
It has less than 18k miles (driven now and then, but should remain under 18K as it currently has 17k and some change).
It has an ASP 178mm pulley, installed around 13k miles
It has the resonator removal, done using BURNS stainless exhaust pieces, similar to BrianBrave's car.
It has K&N Drop in filters.
It has Continental tires
It has NAV
The car sounds great, runs great, and drives great. I haven't seen it in person in over a year and a half, but the last time I saw it the car was in great shape. I would assume it is as good as it was then.
I know he had it in at Bluebonnet Chrysler/Dodge in New Braunfels, TX for a intercooler pump right when he bought it, as well as a headlight replacement due to the hazing/discoloring that they are known for.
He's had Mercedes do the oil changes.
The car is located in/around San Antonio, TX.
There MAY still be a warranty on it, as I know once was purchased when he bought the car. It was 'certified pre-owned' when purchased. I'm not sure if it is transferable or not...you'd have to get with Henry and see if he can figure it out, or give you the necessary info.
I've attached a few pics he sent me.
The gentleman's name is Henry, and he can be reached at :
two one 0 - 829 - zero 5 8 three.
(sorry for the coded phone number, bots are terrible about pulling numbers..)
Another great buy.......roadsters are showing up left an right....
