Thread: Clay Bar BABY!
Old Jun 20, 2005 | 04:49 PM
Rob M's Avatar
Rob M
Wink Re: Clay Bar BABY!
Originally Posted by r.robertson
How do you use a clay bar? Bought McGuires clay bar with spray. If I use too much spray the bar slips over the service not accomplishing much of anything. To little and the clay stick to the surface. Any suggestion would be a help.
make sure you use enough lubricant. you really can't use too much. but too little (e.g. when it sticks) will definitely scratch your paint. the lubricant is what minimizes the abrasively of the clay to enable it to safely clean your finish. with adequate lubrication you can rub back and forth while applying pressure to remove just about any contaminant. to help conserve lubricant, clay your car in the shade. otherwise, the lubricant evaporates quickly. you can always buy more lubricant (any quick detailing spray should do). also, some recommend even using soapy water. they key though is to use enough lubricant to make sure the clay always slides instead of sticking.
my suggestion is to go here and check out holly:
http://articles.autopia.org/index.ph...2&id=31&c=root
now do you see why proper lubrication is so important?
