Old Oct 26, 2010 | 08:46 AM
JimmyJames's Avatar
JimmyJames
Default Re: key fob won't work, alarm goes off - stuck!
Originally Posted by joe lonardo
Jimmy,
Where did you get the ECM and Skreem? can I put it in or is it only a dealer item ? Also how long ago was this and did it solve it for good?
Many thanks
Joe Lonardo
You will not need the ECM if you do not go pas the 30 tries. You will get 3 at a time, then you will need to disconnect everything and you will then get three more---do not do this 10 times. You can get a SKREEM on here at times and on MB WORLD. It is behind the cluster I believe.
Check battery first!!!! This car HATES low voltage. If the battery is under 3 years and checks out, then I would look at the SKREEM next.
Where---the dealer. Time---Two years ago and yes that was the problem---well, the SKREEM was, not the key as first stated. Good luck and let us know. Jimmy
