Old Oct 27, 2010 | 12:01 PM
smfrycruzr's Avatar
smfrycruzr
Default Re: Cruise won't set
Originally Posted by shapeshifter309
The car will re-engage the cruise control once the clutch is released, provided the computer doesn't sense an over-rev. I'm pretty sure this is in the manual. There's no problem with shifting when the cruise control is engaged as long as you don't go from 6th to 2nd or something along those lines of ridiculousness.
As for what the cruise control uses to operate, our cars are drive-by-wire and assuming everything else (which is probably the case) is electrically controlled, then the cruise control modifies throttle input electronically.
I'm not a mechanic, but would have to agree on the theory of the drive by wire method of controling the cruise. It does say in the manual about up/down shifting with the cruise engaged, but shifting must take place under 4 sec. Supprised me the first time it stayed on after shifting, then looked it up in the book.
Thanks for all the inputs, still waiting for my "morning call".
