Old Oct 27, 2010 | 12:15 PM
onehundred80
Default Re: Cruise won't set
Originally Posted by smfrycruzr
I'm not a mechanic, but would have to agree on the theory of the drive by wire method of controling the cruise. It does say in the manual about up/down shifting with the cruise engaged, but shifting must take place under 4 sec. Supprised me the first time it stayed on after shifting, then looked it up in the book.
Thanks for all the inputs, still waiting for my "morning call".
From the shop manual.
Note: A cable and a vacuum controlled servo are not
used. This is a servo-less system.
Control of the speed control system is accomplished by a
speed control switch (1) which is located just above the multifunction
switch (2). The speed control system also uses other
components of the vehicle to accomplish its tasks. The five
other major components used are as follows; The PCM, Accelerator
Pedal Position Sensor, Kickdown Simulator Switch,
Throttle Body and the Clutch Pedal Position Switch (Manual
Transmission). The speed control system is designed to operate
at speeds above 25 m.p.h. (40 km/h)
