Originally Posted by rcompart
Impressive numbers and look forward to seeing what you're able to do with 30PSI when you get there! Just a suggestion, I'd grab the tach signal from the cam sensor so you're not getting the spikes in there. That being said, keep up the good work and I hope to see what your little beast will do when you're done.
how's my afr's at around 27# of boost.. i beleave im still running a lil lean .. what you think?
