Old Oct 31, 2010 | 07:19 AM
Crossfireone's Avatar
Crossfireone
Default Re: Key in ignition for the glovebox lamp to work?
That's the way the glove box light is designed to work It shares the same fuse with the cigar lighter socket. It's also dead until the key is used. Took me a while to figure it out too. Ran an ohm meter across the bulb which always showed good. Then tried the key "trick". Hooray!!!
