big problem with my xfire, please help
Oct 31, 2010 | 10:56 PM
permalink
onehundred80
Apr 2006
25,432
648
Ontario
Re: big problem with my xfire, please help
Quote:
buniqueXF
Its an 04 with 56000 on the clock...and yes it still has the stock white battery in it
This battery at that age is most probably really weak, the electrolyte is probably way down as well.
Put some distilled water in it if its low, fill it up to the bottom of the six fill holes. Check the cables for corrosion and check the grounds.
A weak battery will put out 12 volts or so as long as all cells are still working but the amperage can be low. Have the battery tested under load at a battery seller.
I would suggest that you get a new battery anyway.
These OEM batteries are low maintenance, not maintenance free as they do have the fill holes. After 50,000 miles and six plus years this battery has served you well, say 'goodbye and thanks' to it.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
