Old Nov 4, 2010 | 12:25 PM
No_Dominion's Avatar
No_Dominion
Default Re: Headlight condensation
Originally Posted by s40guy
Well, the only downfall I can find on my new coupe is the headlight condensation. Its been thru rain several times since I purchased it, however it only just showed up today. I have read and printed out the TSB (08-002-05) and will be scheduling an appt. @ the stealership.
My car is out of warranty, so I'm curious as to what others have paid to have this TSB performed. The sheet says it takes 0.2 hrs. but that is probably dealer-speak for 100 hrs.
The other part of me says to just live with it.
I know this subject has been discussed at length, but all of the other threads on this were buried and long dead.
Thanks
Check the back side of your headlamp assemblies. On each assembly there should be 2 rubber caps covering where your bulbs are and 2 "T" shaped rubber drainage grommets. If you're missing any of those items, that is most likely the culprit of the leak. Missing the top drainage grommet is a sure-fire way to get water in the headlamp assembly, I found that out firsthand once.
If you are missing any of the items, the TSB kit you can purchase at the dealership comes with new caps and a replacement plug for the top drainange grommet.
