Originally Posted by s40guy
just called and ordered the kit. I went out and looked and everything that should be there is there, but the TSB will be permanent. (Hopefully) Never had to change a HL bulb in my past XF, so i was unfamiliar w/ the headlight assemblies. Pretty straightforward. Thanks
No problem, hopefully it fixes the issue for you. If after the TSB you still are having moisture problems, then you might have a bad seal where the lens attaches to the assembly housing. But one problem at a time, lets see if this works first.
