Yes you got that right my pride is well gone when i couldnt even over take a camry.. It seems to be engaging 50% of the time and seems to engage more often if i feather the throttle. From higher speeds no sc at all
Thanks for the heads up ill get that checked as well
Originally Posted by robby363
Yup, sounds like it's time for a new IC Pump. It won't hurt anything driving it except for your pride.
. Also check fuse#13 before you replace the pump just to make sure it's not the fuse.
