Originally Posted by FUBU
I got this from a kind person at some of the tuners:
"The SRT has no signal cause there is no wiring. The wing itself is tied into the speed sensors and button in the center console. At the very least I would suggest getting the motor and all necessary wiring that ties into the center console switch.
As for the front lip, it will not impede flow to the HE."
So will anyone want to trade the rear wing of my SRT6 for all wiring, the button and the N/A wing?
The NA wing wouldn't be speed sensitive without being tied to the BCM. You can run it on a dual position momentary switch, with one side supplying power to the motor in one direction and vice versa. You can just hold your finger on the button till the wing is up/down, but youll be able to burn out the motor without the limit switches.
