The NA wing wouldn't be speed sensitive without being tied to the BCM. You can run it on a dual position momentary switch, with one side supplying power to the motor in one direction and vice versa. You can just hold your finger on the button till the wing is up/down, but youll be able to burn out the motor without the limit switches.
Seem to be a hell of a problem to do this.. or? All you that want the SRT wing, get on a solution
haha.. well a manual swith must be possible but a automatic one would be the best...
burning out the motor sounds awful.. what limit switches..? ;D hmm...
